Store up to 99 of your most-called numbers. It’s fast and easy to use. With an eligible Verizon Prepaid Phone Card, you can add phone numbers to your Speed Dial list by dialing your access number and following the prompts for Speed Dial. Assign a Speed Dial code between 01 and 99 to each phone number you save. When you use your Verizon Prepaid Phone Card, simply press the star key (*) followed by the Speed Dial code for any saved number you would like to call.
To manage Speed Dial by phone:
- Dial the access number located on the back of your card
- Enter your PIN when prompted
- Press 5 for special card features
- Press 2 for Speed Dial setup and maintenance
- Press 1 to add or change a Speed Dial number
- Press 2 to delete a Speed Dial number
- Press 3 to review your Speed Dial numbers
To make a call using Speed Dial:
- Press 1 to make a call
- Press the star key (*) followed by the Speed Dial code for the number you wish to call
Select Verizon Prepaid Long Distance Phone Cards offer Speed Dial. To find out if your card is eligible for this feature, simply call Customer Service at the number located on the back of your card.
